JBarca
Apr 09, 2017Nomad II
Old-Biscuit wrote:
Propane hoses or gas pipe
No flexible for regulator or main feed line
Hi Old Biscuit,
Just asking on your statement that seems to have read, " Do not use flexible hose on the main tank regulator." Is that what you meant? If so, are you sure? or did I miss understand something.
If you meant it that way, many many campers are built with high pressure pigtails off the tank valve to the 2 stage cross over regulator and then low pressure hose from the regulator to the main black iron truck line. They use this to allow the tanks to be hooked up easier and the I believe vibration isolation between the main trunk line and the discharge side of the 2 stage regulator.
Please clarify.
Thanks
John
