Old-Biscuit
Apr 10, 2017Explorer III
JBarca wrote:Old-Biscuit wrote:
Propane hoses or gas pipe
No flexible for regulator or main feed line
Hi Old Biscuit,
Just asking on your statement that seems to have read, " Do not use flexible hose on the main tank regulator." Is that what you meant? If so, are you sure? or did I miss understand something.
If you meant it that way, many many campers are built with high pressure pigtails off the tank valve to the 2 stage cross over regulator and then low pressure hose from the regulator to the main black iron truck line. They use this to allow the tanks to be hooked up easier and the I believe vibration isolation between the main trunk line and the discharge side of the 2 stage regulator.
Please clarify.
Thanks
John
That is correct......high pressure hoses/pigtails and low pressure hose from reg to black pipe
OP asked about 'flexible tubing' which I take to be like the flex tubing used to connect stoves...metal tubing
If OP was asking about 'propane HOSES' then YES
Appropriate high & low pressure propane hoses are standard
