adamis
Sep 13, 2020Nomad II
Resealing Compartment hatches, what do I use?
I've started the process of resealing the compartment hatches all around the camper in preparation for winter weather. I did a couple of quick repairs while on the road using silicone sealant but now it's time to do it right.
On the bigfoot campers, there is the fiberglass exterior and then a layer of foam for insulation. The frames of the doors are held in by screws that bite into the fiberglass shell. When I pull the frames out, I see there was a thin layer of foam tape around the border of the inside of the frame. A lap sealant of some type appears to be used to fill gaps between the fiberglass and frame when installed on the camper.
Looking at products on amazon, I see there is foam tape and butyle tape options. It appears that butyle tape is more commonly used on windows. Looking at what was present on the frames I've removed, it appears that foam tape is more common on compartments. Why the differences I don't know...
So anyone who has resealed their exterior compartments, what product(s) are you using and what suggestions / tips might you offer?
Also, on the propane compartment, it appears that some sort of rubber compound was used to completely seal the gas from being able to leak into the camper. This was a bear to get the compartment frame out of and I've never seen anything like it. Wondering what I should use when I put it all back together to keep it air tight.
