Gdetrailer
Jan 01, 2016Explorer III
ccxnola wrote:
My Dometic 7732 got to be more trouble than it was worth!! And there is no direct replacement - but Dometic has a 'recommended' replacement that is $3200 + shipping + install + needed cabinet modifications!!
I started to search for a household fridge that would fit into the opening and found several - but none would go into the rig thru the entry door as they were simply too big. One place even suggested removing the windshield to get the old one out and the new one in - just not practical and cost-effective!!
Long Story short, I purchased a Whirlpool 10.6 cu ft two-door in black from Best Buy (Black Friday sale). It fits into the rig via the entry door (23.5 inches) with the fridge & freezer doors removed. PLUS there is now an added space about 7 inches wide and 23 inches deep alongside the fridge as it is narrower than the 7732. AND that space is now an added pantry with several shelves for storage! WIN - WIN
Total cost? $526 for the fridge, added 3-years service plan and delivery to the RV shop for installation. PLUS $1100 to remove the 7732, install the Whirlpool and custom build the pantry with a secure door. So at $1626 I have a professional installation of a new fridge.
If I had the skills, tools and cabinet making skills, I could have saved that $1100!!! (OH - it does take at least two people to man-handle the 7732 out and the Whirlpool into the rig.)
I figure we mostly are staying at places with 120v electric service and the infrequent boondock nights, the generator will run for awhile and the fridge will stay closed most of the time - so I did not go to the expense of a big battery bank and inverter to run the fridge when we are off-grid as that is not a usual situation for us.
In my case, I removed the entire aluminum DOOR FRAME, that gave me an additional inch or so to work with. Inside framing dimension for a 24" door is a little over 24" but with the aluminum door frame in place the opening was about 23"..
For some folks they have had to resort to removing a window then use a forklift to get the fridge to the window opening..
But you definitely must measure the perspective fridge and your openings carefully.
44,056 PostsLatest Activity: Jan 12, 2020
