theoldwizard1's avatar
theoldwizard1
Explorer II
Aug 06, 2018
Residential tankless water heater
I just discovered that several companies make an OUTDOOR residential water heater. Not the cleanest looking thing hanging out the back of your TT or 5er, but you will have tons of hot water !
Has anyone installed one on their RV ?
  • I might consider a hybrid for home use, but I'll stick with the tried and true 6 or 10 gallon gas/electric water heater for my RV.
  • seaeagle2 wrote:
    If you're talking about a tankless residential water heater, they require 110V, (no biggie), they are 199,000 btu, so usually requiring upsizing a residential gas line to 1", I'm not sure how long a RV sized propane tank could supply enough propane for 199m BTU.
    Rheem make a couple of different models. They do require 120V AC for ignition, but the installation guide says only 1/2" gas pipe is required (the one I linked is 160,000 BTU).
    Shipping weight is 54 lbs. There is quite a bit of plumbing (hot and cold water, gas, electric, PT valve outlet, etc.) below so I would want some kind of cover for all of that.
  • If you're talking about a tankless residential water heater, they require 110V, (no biggie), they are 199,000 btu, so usually requiring upsizing a residential gas line to 1", I'm not sure how long a RV sized propane tank could supply enough propane for 199m BTU.
  • We have a friend with one at their house (propane). I don't know what brand it is but it works fantastic at all flow levels.
  • They're rather huge, many require 240 and probably not good for vibration.
