DutchmenSport
Nov 10, 2014Explorer
I've seen several refurbished TT's and PUP's turned into all sorts of things. Yes, you can do it. The only thing you might consider is getting the trailer re-titled as a utility trailer instead of an RV (at least in Indiana they are different). The tags for a utility trailer (in Indiana) is much less than an RV (trailer). You might have to get it re-inspected by law enforcement to verify the VIN is the same trailer, but used for a different purpose and titled different. Anyway, before ripping it apart, you should check your state DMV first, just so you're prepared. Other than that, you should be fine doing this project.
44,068 PostsLatest Activity: Jun 19, 2026
