Gdetrailer
Nov 10, 2014Explorer III
MM49 wrote:
A TT frame on its own is not very strong at all. TT frames are part of a system that draws strength from all of the components in assembly. The capacity will be much less that the original TT.
MM49
Correct answer.
While folks have done what your thinking about the net result will be a much weaker trailer since the walls create a "truss" system. Taking away the walls would have the effect of cutting notches in the frame of a properly built utility trailer..
My suggestion is to sell the trailer, you should have no problem getting at least $400-$500 for it as is.
There are folks who are looking for vintage trailers and are not afraid to put some work and money in it.
Put in on Craigslist, it is free to do so..
Take the sale proceeds and buy a ready made purpose built utility trailer.. You should have no problem finding a new 12-13ft utility trailer for around $1000-$1200.. In the end you WILL be happier with a properly built trailer.
44,068 PostsLatest Activity: Jun 19, 2026
