harley4275
Apr 03, 2017Explorer
I have a 2013 that had 3500# axles and springs and like you ,I did the scales loaded and was under the weight by 600 lbs ...but springs were flat and tires were bottoming out on bottom of trailer wheel well. One axle straightened so had 4400# axles and matching springs installed. (4400s are 5200s with original 10"brakes instead of 12" brakes.)Kept original rims and they supplied same size tires ,so my GVWR stayed the same as tires are now the weak point. I guess you could say the frame also.
I added wet bolts too and a much quieter ride.
44,067 PostsLatest Activity: Jun 03, 2026
