tsetsaf
Mar 31, 2015Explorer III
Follow-up on this. So I went through the Riderite.com Warranty Claim submission and submitted all the information. Here is the email response I received:
"Thanks for the pictures but I’m sorry to say that we will not be able to cover this under warranty. The reason is because we are only allowed to cover manufacturer defects and this is not a sign of one. The upper bracket has a hole that this pin goes in and this happens when either the pin is not installed in the hole, or it is installed in the hole but the nut on top of the bag is not tight enough and it allows the bag to rattle and rotate the pin out of the hole. In either case the pin is not in the hole and is now under the upper bracket and it beats on the pin until it starts to leak and eventually pushes it in. The only way to fix this is too buy another bag."
The response was unsigned and the return email address was [email protected] . So I have no idea who this is, what their role in the company is or anything.
Basically they took the route of "not us" it's "you" like so many "lifetime warranty" products in this world.
Frankly I am pissed. I have babied these things and am religious on keeping them properly aired at all times, jacking from under the axle for tire changes, etc etc. Plus the pin was properly placed in the relief and all the attaching nuts were tight (I have knuckle scars to prove it from getting the bag out).
Obviously I am not sitting on this and will keep pushing. Will let you know how it turns out.
