ssthrd
Jul 24, 2023Explorer
I had a look at a video on these things as you suggested Gd Thanks.
I took the head off, and found that the shaft in the tube spins freely. As you would expect I guess. I swapped both rear heads (just plugged them in), and same thing. The bad one has continuity, so I figure it could be a broken gear with maybe a chunk gumming up the works.
WD40 is my friend hopefully. I doused the screws holding the top cover on. One unscrewed nicely after a few taps with a hammer on the screw driver, but the other one won't budge. Rather than strip the head, I'll let it soak overnight and try again tomorrow with a few more love taps, and maybe I can coax if off then. Last resort is drill and easy-out. Hopefully I'll find an easy fix then.
