GeoBoy wrote:
F450EC1165 wrote:
I replaced them on a 2010 AF 990 I used to have, if I remember correctly my RV dealer was able to get them for me.
One other thing, when I removed the bolt on the bottom to remove the foot pad, water poured out, the rear two jacks tubes were probably half full of water.
I've wondered if there should be a drain hole?
All four of mine have holes for drainage. I shot Amsoil HD Metal protector in the holes to coat the bolts in case I want to replace my boots, which are cracking.
Today I was able to check the jack legs on my new 2017 990, they also have the drain holes, Rieco must have decided the drains holes were a good idea.
I think I'll spray some rust inhibitor inside to keep the bolt threads from rusting.
