Charles2222
Jun 26, 2015Explorer
I have an easy2 hitch with same set up .The bolt is 5/8 with 15/16 wrench size.The end of the bolt keeps digging into shank,so I pulled it apart and screwed the bolt in backward with head of bolt to the shank giving more surface on shank.I then put a lock nut on the threads sticking out.I will later make some better way of doing this as I had to tighten it with channel locks I will cut the bolt out when I'm ready to build something,as we are leaving for points west and Yellow Stone on July 6 and not enough time to think it thru
44,066 PostsLatest Activity: Mar 14, 2015
