blt2ski
Feb 05, 2022Moderator
pianotuna wrote:
time2roll,
I'd love to suffer with you!
I think there is going to be plenty of suffering from ALL sides until better batteries built, quicker charging, more charging places closer together, before electric rigs can come into play, and or taker over the ICE rigs.
With this said, EV's have the power it seems to pull larger loads, with out overheating as bad as ICE rigs per say. Doing 70 up the road it did, is doing fantastic IMHO. A TD in a 25/35 rig may pull that trailer at those speeds, not positive the biggest ICE motor in a 15 series will!
With the above said, it would be also I teresting to see how much fuel per say was used at the legal towing speed, I believe 55 in CA, or 60 generally speaking in the other states and Canada, vs what appears to be a pedal to the metal speed test! How much farther would the maxed out speed limit rig be able to go before charging the battery(s)? To add another comparison to what many other comparisons others have thought up!
Marty
