- CharlesinGAExplorer
otrfun wrote:
We chose the Roadmaster over the Hellwig for our Ram 3500 SRW because it mounted to the axle housing in a more outboard, OEM fashion, at the bottom of the shock mounts. The Hellwig mounts more inboard with a clamp around the axle making it less effective IMO. We also installed lower Stable Loads (stainless steel versions). They offered some improvement in sag, handling, and even reduced sway slightly (at highway speeds)—-nothing dramatic. They work especially well when used in conjunction with slightly pressurized airbags.
I bought a Hellwig for my '03 2500 RAM. I was not happy with the mounting setup to the axle, as it clamps right at the point the axle tubes go into the differential casting. The Roadmaster picks up the stock mounting points on the shock brackets, further out, so the bar does not need to be as thick to have the same effect.
The Hellwig has been sitting in the box for a couple of years now, I guess I ought to get rid of it.
Charles - silverbullet02ExplorerI have the roadmaster and it has worked great for me. I'm currently camperless, but now and if I didn't plan on using the camper for a couple months or more I take it off, only takes 5-10 minutes. Makes the truck ride stiffer than the 19.5s did unloaded.
- Bert_the_WelderExplorer IIHaving not ever even looked at a sway bar:
Are they easy to disconnect? (Like a couple easy to get to bolts type thing)
And does leaving what ever part is being disconnected bad or potentially bad while driving it around? (As in anything hanging down to get caught on a curb, speed hump,etc)
And a they easy to temporarily detach on some truck brands and a pain on others?
Thanks for the lesson in advance. :) - Geo_BoyExplorer III have a GM truck and I went with the Roadmaster because of the way it attached to the rear of the frame, instead of attaching to the midsection of the frame.
44,029 PostsLatest Activity: Jan 13, 2025
