BradW's avatar
BradW
Explorer II
Oct 21, 2019
Roadmaster Sway Bar 2018 F350 4X4
OK, just got back from our first real road trip with the new truck and camper. Didn't take long for me to realize I had a LOT more sway with this truck/camper (2018 F350 DRW, tembrens, oem shocks, longer/heavier camper with CG farther back) than our last one (2006 F350 DRW, timbrens, rancho 9000s).
Based on the always 100% reliable Internet information, I ordered a bigger rear ant-sway bar; Roadmaster (1139-193) from etrailer. Arrived very quickly; only 2 days with free shipping. As stated on the etrailer website, it was easy to install and only took about 1 hour. Only tools required are a 1/2" ratchet wrench, 18mm socket, 13mm socket and some blue Loctite.
The new sway bar is 1.5” diameter vs the OEM bar at 1.0”.
Results: Sway is much reduced. I’ve only done a couple of short test drives, but the side to side rocking has been reduced about 80%.
One other issue I had before the new sway bar was with the steering. I think I was getting so much side to side rocking that it was affecting the steering. It kind of felt like “bump steer” that can occur when a 4X4 is lifted and the steering geometry is screwed up, so when the front suspension articulates, the front wheels turn slightly to one side or the other. That problem is completely gone now with the new Roadmaster sway bar.
Conclusion: I’m very happy with the new sway bar. It does what it is advertised to do and what others have said about it on the Internet. I wished I had bought it before our 4,000 miles trip to Yellowstone and Moab last month. It would have made the interstate driving much easier.
Roadmaster Sway Bar Photos
bradw
