BillB800si
Apr 12, 2015Explorer
handye9 wrote:
One of those two valves, works exactly the same as a trailer with only one dump valve. It has one pull handle for the black tank, and one pull handle for the grey tank. The other dump valve, has one pull handle for dumping the galley tank.
There are "Y" fittings that can be used to connect everything into one dump hose.
My trailer is set up this way. One 38 gallon black tank, and two 38 gallon grey tanks.
Oh I understand the idea. It's just a pain in the butt to crawl around under the slides to dump. Plus I have to get a above ground sewer hose support for the cross over and one to the ground sewer connection. All because someone can't design a proper- simple main dump vale assembly.
And talking about designs- keystone Cougar Xlite trailers this year came out with a no walk on roof and the ladder is no longer available. They even removed the wall supports so that the dealer can't install a ladder.
Happy trails,
