Old-Biscuit
Apr 12, 2015Explorer III
BillB800si wrote:PawPaw_n_Gram wrote:
Because RVs have very limited room under the floor - it often isn't feasible to drain a sink into the same grey water tank as the bathroom shower.
With a front kitchen and mid-rear bathroom - the 3008W has a 38 gallon black tank and a 38 gallon grey tank at the back. This has to be the primary drain location because the black tank has to have the 4" diameter outlet pipe. The kitchen has a 38 gallon tank. There simply isn't enough rise/ fall to run the drain from the kitchen sink to the rear grey water tank.
The 8310SS has the same issue - the rear kitchen sink is too far from the bathroom for using one grey tank. It also has two 38 gallon grey tanks and one 38 gallon black tank..
Except our 2006 32 foot Jayco Eagle 322FKS we had, had a front kitchen and a mid bathroom with only one drain outlet.
Just saying..... :)
Kinda depends on which side of ax;es waste tanks are.....
All in front or back can use a drain header
Tank(s) front and aft of axles make it harder to use one common drain header
