Kcskitek's avatar
Kcskitek
Rockwood Roo 21SS - Tow Vehicle
I am in the process of downgrading my Tow Vehicle from an '08 GMC Yukon Denali rated at 8100# towing max to a Toyota 4Runner w/4.7liter V-8 rated at 7,000# capacity. I am also looking to upsize from a PUP to a HTT 21SS Roo. The dry weight is about 4,300# and 1,200# carrying capacity, but the hitch weight is relatively high at just under 600#. The 23SS has a much lower tongue weight at 435#. Will I be okay pulling the 21SS with a WDH with the 4Runner? Trying to figure out what the maximum tongue weight is. All that shows up is the maximum towing load of 7,000#'s. Also, does anyone know if the factory tow packages on the 4Runner's have transmission coolers. How do I tell if they are factory hitches? Thanks!
  • Chuck_S wrote:
    The tongue weight on my Roo 23SS will easily exceed 700 pounds in camping trim.
    What year 4Runner has a V8 engine and 7000 pounds maximum towing capacity?
    You absolutely need a WDH with any trailer of this size even when towing with a truck.
    -- Chuck
    What are you pulling your 23SS with? The 4Runner's I have checked are the 2005 and 2006 V-8 4WD 4.7 liter motors. The 2WD actually will pull a little bit more weight. What is the formula on tongue weight with the trailer I plan on purchasing? I have heard 10% of the dry weight of the trailer, but get confused with the overall GVWR and the load weight.
  • Not a lot of help here other than to tell you that our '07 23SS, ready to pull out of the driveway - minus anything in either the black, grey or fresh water tanks - weighs 5000# on the nose. DH seems to recall the tongue weight as slightly under 500# loaded. We tow with an '03 F-150 Crew Cab rated at 8000# with the factory tow package. IIRC, the 21SS has a heavier weight and tongue weight than the 23SS.
    To find out exactly what's what on the 4Runner, go to your dealer with the VIN# in hand and they can print out the specs. It'll be straight from the line and no "salesman declarations" to try to understand. Feel free to come back here with the numbers and you'll get all the help you need.
  • The tongue weight on my Roo 23SS will easily exceed 700 pounds in camping trim.
    -- Chuck
