beemerphile1 wrote:
FWIW, it appears you have three receptacles in that space. Those RV/mobile home receptacles are very prone to loose connections if you start moving those wires around.
I would probably eliminate the microwave receptacle completely.
I would remove the other two receptacles and replace with an "old work box" and residential/commercial receptacles. I would put the Romex in Wiremold surface mount conduit.
Sounds like a good plan, thanks. I would need to trace the microwave receptacle all the way back to eliminate it correct? If I cannot do that what is another alternative?
