SparkDr wrote:
dmullen wrote:
The outlet on the left side is labeled with a sticker as a GFCI outlet but has no test or reset button and looks exactly like the outlet on the other side. :?
It's probably GFI protected upstream in the circuit (likely the bathroom). FWIW, somebody should have at least suggested to the OP that a call to an electrician may be warranted. I'm all for DIY when it makes sense, but I get the feel from what I'm reading here that the OP should stay hands-off on this one. As a past Sparky in a previous lifetime, I can say with all honesty that I have not seen a recommendation to do what I would have done in this instance. Nor would I feel comfortable trying to explain it step by step in a forum. Be certain of what you are doing and do it safely when it comes to electricity. These things already go up like a matchstick without our help.
I joined this forum to learn. Because of this forum I was able to hard wire a Progressive Industries EMS into the camper...learned how to pack wheel bearings...installed two Fantastic Vents...removed the oven and replaced with a new cooktop...installed shocks for the under bed storage...just to name a few. I learned by reading and asking questions and have saved a ton of money by not staying "hands off" and calling someone else to do the work and I plan to keep doing it that way. There are several intelligent people in this forum and I have not been steered wrong yet.
