westend wrote:
SparkDr wrote:
dmullen wrote:
The outlet on the left side is labeled with a sticker as a GFCI outlet but has no test or reset button and looks exactly like the outlet on the other side. :?
It's probably GFI protected upstream in the circuit (likely the bathroom). FWIW, somebody should have at least suggested to the OP that a call to an electrician may be warranted. I'm all for DIY when it makes sense, but I get the feel from what I'm reading here that the OP should stay hands-off on this one. As a past Sparky in a previous lifetime, I can say with all honesty that I have not seen a recommendation to do what I would have done in this instance. Nor would I feel comfortable trying to explain it step by step in a forum. Be certain of what you are doing and do it safely when it comes to electricity. These things already go up like a matchstick without our help.
I tried to hint at that in a previous post. The OP had another thread about vacating a 12V device and decided, without checking phase, to connect similar colored wires together. That's what you see in the pictures in this thread with the wire nuts.
I'd suggest that the OP at least enlist a friend or neighbor that is conversant with 120V wiring, if not hiring an electrician.
BTW, try to buy those single gang boxes in the "shallow" variety. You will have a lot less box in your way.
I probably should have tried the hint method first myself. Everybody gets offended so easily nowadays. I stand by my opinion. OP doesn't know his backside from second base when it comes to proper line voltage electrical circuitry and practices. While we all want to be helpful, a platform such as a forum oftentimes offers such a mish-mash of suggestions that the end result becomes misinformation as interpreted by an OP. Enlisting a friend or neighbor "in the know" is a great idea. In some cases, so is hiring an electrician. It's a small project that wouldn't cost very much at all and most pros that I know would be flattered to have someone ask them to offer a little instruction for next time while doing the work.
