AcdiiExplorerApr 18, 2019Roof coatingThe 5 YO roof on my Coleman is starting to show black across the trusses, which is the coating wearing off. Last fall when I washed and protected the roof I tried scrubbing to see if it was on top or ...Show More
gboppExplorerApr 18, 2019X2 on the Heng's Rubber Roof Coating. It did a good job for me and is holding up after tbree years. No primer is needed and is easy to apply. I used 2 1/2 gallons to cover 30' of roof with two coats.There are other coatings available, check them before you decide.I'll use Heng's again.
Related ContentBest Roof CoatingRoof coatings.Are you familiar with Duck Coat Roof Coating??roof coatingBest roof coating for aging rubber roofs
