daveor wrote:
RV daytrader wrote:
Telescoping ladder easier to climb as it is at an angle, NOT straight up like a mounted ladder. Check your slide topper??..Would you rather place telescoping ladder next to the slide and climb up 5 rungs to check or clean topper OR climb up rear mounted ladder up to the roof, walk over to slide area to check or clean, walk back across roof to rear ladder and climb back down? My telescoping ladder takes up 4 inches of my closet space.
Can I ask what kind of ladder you have that only takes up 4inches.. thought about putting a ladder on mine too,, but not thrilled about more holes either.
It is a 10 foot telescoping ladder...about 29" high when closed, 18" wide...the thickness is about 4"...my closet is about 19" deep, so it stands against the side wall with a bungie cord holding it in place.
