I can see how staying at the beach for a week or more can be a challenge with managing water usage. Not like it's an easy thing to pack up and go get water or dump. Bedlams suggestion is what I'd do. Get yourself a pump, rig it up under the hood of your truck and enjoy
DutchmenSport wrote:
Mount the tank on a sheet of plywood by putting eye-bolts through the plywood on each side of the tank. Then with ratchet straps or good tie downs, attach the strap to the eye bolts on each side of the tank, put the strap over the tank, and tighten the strap down. The board itself is placed on the top of your camper, spread out over a wide area (like 4x4 feet). You have to figure out a way to anchor the plywood down, but that would spread the weight on the roof and make it easy to remove.
You're just asking for the edge of the plywood to gouge the roof membrane by doing that.
