Huntindog
Apr 13, 2015Explorer
yankeeslover wrote:When you ran the heater... Did you take any prevenative measures against condensation? Like opening some windows and/or vents, or run a dehimidifier? Have you ever done these things when running the heater? If not, then you are at risk of condensation, and the slow destruction it reaps. Condensation is like a slow silent deadly force. It's damage builds slowly imperceptibly. Take measures in the future to prevent it. Ignore it at your peril.
2 year old camper..upstate NY. I took my camper home this past weekend from outside storage... of course its been cold as heck up this way all spring. Friday and Saturday night i worked in the camper while i had the furnace on heating it up(first time since oct any heat in camper).
Yesterday and today were both finally almost 70 degrees up this way. inside of camper is around 45-55 degrees right now..OK. so i was out walking on my roof an hour ago. just checking the dicor like i usually do and i noticed that when i walk by the fantastic fan the roof creaks(not overly concerned as im sure this is just the plywood creaking). but just to check and make sure no leak i decided to take off the speaker inside the camper that is right next to the fan so that i can check around. I started to freak out when i noticed the top of the speaker seemed damp..same with the insulation that was touching the speaker... I instantly figured i have a leak somewhere..
I just took off the other three speakers for sh__ts and giggles and to my surprise noticed that all 4 speakers seemed alittle damp on the top and the insulation touching it was the same. two of the speakers are on the opposite end of the camper.. I now wonder if this could be a simple case of condensation. like is said its finally warm up this way and the sun is baking on the roof while inside the coach it is only around 45-50 degrees... NOONE is in the camper though.. is this possible that this could just be condensation or does this sound like a huge leak in the roof that is effecting the whole roof(I wouldnt think so)... what else can i check to confirm its not a leak? nothing else is out of the ordinary..thanks...
44,071 PostsLatest Activity: Aug 30, 2026
