WVbassmistress
Oct 23, 2013Explorer
Roof rebuild on pop-up
What started out to be a smallish leak on the front of the pop top of our Bronco, has turned into pretty much a total rebuild. Bless my DH's heart, he is giving it his best shot but needs some help. Any takers????
When we thought it was just going to be replacing the panel on the front, we picked up some PVC board (I hope that is the right name for it) hoping to eliminate future rot and be light weight. It is 3/4 thick. Is this strong enough? Now we have found at least one side has water damaged rotted wood and needs replaced so the question of strength is more critical.
So...while tearing into the sides, he decided to just redo the top. Evidently what we assumed was plywood under the aluminum, is just some kind of wall board sandwiching thin insulation glued to the aluminum. - I hope I got that right. Should he just try to duplicate that or has anyone improved on that?
If anyone has tackled a similar project your input (and pictures) is greatly appreciated. Not even sure where to get some of this stuff. We had a guy say the wallboard type stuff can be picked up at a mobile home supplier if not at Lowes, etc. Then I assume a fabrication shop could do the aluminum skin and new trim .
I was so down-hearted I wanted to just run it to the dump, but he is determined to make this work FOR ME. He is pretty good with anything he has ever tackled and, being an electrician, is quite the perfectionist. This little experiment was my idea. We do enjoy the TC, just can't afford to get the dream camper right now.
Thanks in advance!
Thanks in advance!
