Had started the restoration process of my '79 Coachman little over a year ago, Sadly as I started pulling out the interior I found that the only thing any good was the aluminum shell so the project wa...
Another thought I just had. Since I will be using the eternabond tap around the entire patch should I try and remove the top trim rail between the roof and side wall or just leave a lip on the roof to attach to?
