Blackdog79's avatar
Blackdog79
Roof Repair
Had started the restoration process of my '79 Coachman little over a year ago, Sadly as I started pulling out the interior I found that the only thing any good was the aluminum shell so the project was scrapped. Picked up a 95 Prowler 27x for a good deal. Now, thanks to the lovely winter we had in PA I have a hole in the left front corner of the roof, two broken ceiling joists, and a cracked top rail. Thankfully I can back it inside my shop to be able to work on it but still a mess. Now to my question... I am going to cut the first 7 feet of the aluminum roof off to give adequate access to the joists and hopefully be able to tie in a patch plate on the top rail. I can get a 4x8 sheet of aluminum from a local supplier for $34. Was planning on using roof sealer caulk and pop rivets to install the patch, as well as caulking the seam from the inside. Once caulk is dry next step is to be eternabond tape around the entire patch. Does this seem to be a sound plan? Also what is a recommended coating to go over the patch panel since it is bare aluminum, as well as coating the rest of the roof while I'm up there? I'm hoping to get this taken care of for around $500 if possible.
  • I actually already cut back the roof half way across, and also the wall down to the chair rail. Once the roof is well sealed I'm going to use a screw jack to lift up the rafters enough to give access to the top plate to repair it and then sister on some joist boards. Hoping it is a quick and easy repair, and would be even better if I am under budget. Side note, I checked and all I can get from local supplier is bright or painted sheets, no vinyl coated. Do you think it would be worth using a few rattle cans worth of paint on the inside?
  • To repair the top plate in the wall, you will more than likely have to either remove the interior paneling or siding in that location.
    The rafters will be attached to the ceiling so a manner of eliminating that fastening will be necessary unless you can jack the ceiling into position and sister-repair the rafters from above.
    I buy a fair amount of aluminum and my local distributor sells vinyl coated aluminum sheet in various dimensions. The vinyl coated sheet goods offer some cosmetic upgrade and are easy to paint.
    Sealants: Stay away from anything containing silicone. Rather than an off-the-shelf roof patch material, I'd suggest you aim for a polymer or urethane sealant. Geocel sells a variety of sealants for mobile applications, all of which are polymer based.
    Eternabond tape is a great sealer, i have it on every seam on my roof. When I was done applying the Eternabond, I sprayed two coats of acrylic roof paint over the entire roof. If you are going to be coating bright, unfinished aluminum, a primer has to be used. I recommend Sherwin-Williams Industrial DTM primer, it is listed for bare aluminum.
    Your budget could even be high for this project. Good luck.
