BillM2
May 27, 2019Explorer
Roof repair
I have a 2005 28’ Fleetwod with roof issues. The rear two feet of the roof is beyond spongy. It feels as though just the membrane is there with no structure really underneath it. Question: for I’ve...
BillM2 wrote:
Should I remove the entire side rails or just enough to work the roof? I know the rear has to come off. Would a heat gun on a low setting help release the membrane from the sub material?
The membrane is white so I’m assuming it’s EPDM?
And if the insulation is gone, what do you recommend to replace. Rigid or bat?
