Just finished completely replacing the roof on my Thor Freedom Spirit 180. It had leaked at the TV antenna and damaged the forward most roof panel. After lots of anguish and research, I bit the bullet and stripped the roof entirely (I have a shop to work on it in, so no weather issues) and since the adhesive needs fresh wood for the water in it (water based adhesive) to leach into so it can cure, I was faced with two alternatives. Overlay the entire roof with a thin layer of Luan (and screw up the spacing at the corner trim overlaps) or simply replace ALL of the roof sheeting, which is what I did.
While the roof was open, I reinforced the trusses with 3/8 plywood that was glued with construction adhesive and stapled to the trusses. Put the new wood down with screws. It was a LOT of work, but it came out nice. The antennas are now in the scrap pile. I removed both the radio and the TV, so no need for the antennas.
Awning was weathered but serviceable but since it was removed, I replaced the vinyl. I also installed a new Maxxfan Deluxe in the place of the no-fan vent, and installed new waste tank vent caps.
Did I say it was a LOT of work? I have a good stable 8 ft ladder and an electric scissor lift, plus a couple of articulated ladders (little Giant) so the job is doable with the right stuff.
Been working like a madman on it trying to get it ready for a trip out west in a couple of weeks.
Charles
