BillM2's avatar
BillM2
Roof repair
I have a 2005 28’ Fleetwod with roof issues. The rear two feet of the roof is beyond spongy. It feels as though just the membrane is there with no structure really underneath it.
Question: for I’ve seen video postings on how to redo the entire roof, but wondering if it can be done partially. I’d need to go the full width for the final 24” of so. How would the seam be handled, if so? Can a seam be sealed properly? The rest of the roof is solid.
If anyone’s done this, any advice?
Thanks!
  • Don't cut the membrane and make another seam up there. Its just another source of leaks.
    Do it right.
    Remove all the screws in the cap/roof membrane molding.....remove screws on the drip rails both sides....other roof fixtures and roof jacks past the rotted area.....then roll the membrane past the area your going to replace.
    Replace damaged wood......then replace it all with a good seal job.
    Let google and youtube work for you on this project.
  • I think if it is that spongy the wood below the membrane is rotted and needs to be replaced first. After that you will likely need a whole new membrane roof.
