Has anyone replaced the roof on their TT? Going to do this myself. The 20 year old rubber roof on ours is due. The Dicor products look good and reasonable price. Briteply vs. Britetek? Can i go righ...
Going over the existing roof shouldn’t be a problem IF… The existing membrane is Still well attached with good adhesives… The adhesive use to install the new membrane is compatible with both the old and the new membrane… The new adhesive won’t cause the old rubber to swell or penetrate the rubber and cause the old adhesive to release its grip while curing or over time… Prepping is everything almost, or at least the most important thing…
