bobvila
Oct 22, 2015Explorer
Roof screw holes repaired by Dicor???
Hello All,
I need please your advise. I'm a newbie and I'm looking to buy my first RV Kodiak 200QB 2015.
The dealer had only one model in stock and this model won't be available next year (MD)
Unfortunately, they installed this summer a Solar Panel one this RV instead of another.... So they removed the solar panel and they repaired the 4 holes on the roof with only Dicor.
As I mentioned, I'm not an expert but I thought that should repaired the hole with a fabric backed seal tape 4inch x 4inch on each hole and sealed the edge of the fabric with Dicor, instead of adding only Dicor directly in the hole...
I will probably adding a Solar Panel at the same place but not fixed on the roof at the same hole. So the existing hole must be 200% water proof.
So can you tell me if the way that the dealer repaired the hole is ok or I should ask to start over with a fabric tape?
The existing holes will be probably under my future solar panel, so I will secure my panel with a tilt mount kit in order the be able the check the hole by tilting my panel.
Here a picture of one of the hole.
Any comments will be greatly appreciated!!
