al7601's avatar
al7601
roof top air conditioner KWH?
we have to pay our own electric at our seasonal site of $.25, yes I know its a lot, and wanted to know from experience how much the air conditioner will draw on average per day? its a 33 foot TT and I believe the AC is 13500 btu. Naturally the air is automatic and will shut off once it hits a certain temp, say 72F.
  • Hi,
    My 13500 Dometic draws between 1200 and 1900 watts. Duty cycle is dependent on ambient temperature.
    Invest in a kill-a-watt meter.
    Going with worst case, 1900 x hours of run time would be the safe way to calculate.
    At 0.25 cents I'd run the fridge and water heater on propane.
  • Mandalay Parr wrote:
    Mine draws about 13 amps. Multiply that by the number of hours it runs. Then divide by 1000 times your .25.
    The other option is to remain hot. I don't like hot. My Comfort Is worth it.
    You left out a step.
    13 amps times 110 volts = 1,430 watts to run AC
    1,430 watts divided by 1,000 = 1.43 kilowatts to run AC
    1.43 kilowatts times 1 hour = 1.43 kilowatt hours
    1.43 kilowatt hours times $0.25 = 36 cents cost to run AC for 1 hour continuously
    You will have to estimate how long that bad boy stays on. Sweating isn't my thing either.
  • Thank you both for explaining it that way, makes sense.
  • Mine draws about 13 amps. Multiply that by the number of hours it runs. Then divide by 1000 times your .25.
  • This is very rough, but here goes:
    I'm not sure how many watts 13,500btu is so I'll just say it's 1200w (10a) running a 50% duty cycle
    1200w x 12 hr/day = 14,400 w-h/day = 14.4 kwh/day
    14.4 x $0.25 = $3.60 day
    As I said, very rough, but you can substitute your own numbers.
