covered_wagon
Jul 01, 2017Explorer
Most you need to disconnect the cranking arm off the vent top by opening all the way and unscrew the crank gear housing. There is a slot on the crank arm roller track that allows the arm and roller to come off the lid and track. I think you might have to remove the screen to get to everything.
I think most you then slide sideways to get it to slide off of the hinge pivot when you hold it open without the crank. Be gentle.
44,071 PostsLatest Activity: Aug 30, 2026
