RoyBell
Aug 04, 2015Explorer
2012Coleman wrote:RoyBell wrote:So your vent caps are open? I don't get it then. Unless your entire vent is covered by a maxx air cover and the vent is open inside it.
Only issue with putting something over the opening is, it blocks airflow then.
If that is the case, and you want to sleep late then you will have to forgo the airflow , cover the hole with something and turn on the ac.
We leave the roof vents (caps) open at night to let the heat escape. I was saying if we put something solid over/under the screen, it will block the airflow out the vent, which is the whole point of the vent.
I was seeing if there were other options than the $50-$100 air covers. I do like that I can keep the vents open in the rain though. However, I also don't want to spend the money :). I will check out the dark screen. Maybe that will work.
44,056 PostsLatest Activity: May 04, 2014
