Moochie
May 09, 2023Explorer
If you use a portable, you would need at least 1.5 times the btu capacity of your roof mounted unit because portable units are MUCH less efficient.
You probably have a 15,000 btu unit. 20,000 to 25,000 btu portable units are quite rare. Check Lowes, HD and Amazon. They would probably run $400 to >$800. It should be worth getting your built in unit repaired. At least get a couple of estimates.
44,071 PostsLatest Activity: Aug 16, 2026
