F_B
May 09, 2023Explorer
opnspaces wrote:
Portables just flat out suck. If you sit right in front of the portable it might cool you down.
The downside of a portable is it has to exhaust the hot air to the outside that it creates when cooling. This causes a negative pressure inside so the new hot outside air gets pulled into the trailer to relieve the vacuum.
That is true of single-hose units, which I agree are just about useless because of the pressure differential you mention. If you get a dual hose unit, it both draws and exhausts air outside. No pressure differential with those.
44,071 PostsLatest Activity: Aug 16, 2026
