dfrank
Feb 05, 2017Explorer
rotted tie down point, how to fix?
I have a '98 Fleetwood Caribou.
I knew it had some water damage when I got it, but it is worse than I thought.
The bottoms of the side rails are delaminating, but also the framing member that one of the tie downs mounts is failing, It also has one area where there was a leak in the roof, where the rim joist has rotted out.
What would be involved in peeling apart the layers to add a new framing member to mount the tie down to?
Is this thing really framed out of just 1x members? I was going to cover the delaminated bottoms with some sheet metal, but the failing mount is really the bigger problem.
Thanks,
Thanks,
