Hi, we have just discovered that the floor in the entry of our TT is spongy and the vinyl is bubbling up. I’m sure this indicates there is a leak somewhere. The trailer has been parked for several mon...
If just inside entry door, this is a common spot for leaks. Many doors do not seal well, even high up, and the water runs down, comes inside, possibly under the vinyl flooring. Another possible source of leaks, also common, is the window in the door. Water can get inside the door, from a leaking window, and come out the door bottom, on the inside.
