crcr
Nov 28, 2019Explorer
Routing Solar Wiring from Roof to Pass Through Storage
I'm about ready to install a solar system on our 28' 2011 Jayco TT. Solar panels will be on the roof with the wires from each going to a roof combiner box, then a pair of wires from the roof combiner box going down to the pass through storage, where my solar controller, inverter, etc, will be mounted on a piece of 3/4" plywood opposite the two 6V batteries on the tongue.
To minimize voltage loss, I want to route the wires from the roof combiner box, which will be in the center of the roof at the front of the TT, to the solar controller in the pass thru storage via the shortest possible distance. The shortest route is down through the front center of the TT, between the front cap and the paneling on the inside wall. In the pic below, you can see the inside wall. I removed the decorative headboard which is held by 3 screws, and behind that is the same paneling.
I don't know for sure what is behind that paneling. I recently drilled a hole for another project in the rear wall of the TT, and the insulation there was solid styrofoam. Should I expect that the insulation between the front cap and the inside paneling is also styrofoam? Or would it likely be a different material?
If it is styrofoam, any suggestions on the best way to route a wire from the roof down through it? I can take my oscillating multi-tool and from the inside cut one or more access openings into the front wall, behind where the decorative headboard fastens. For obvious aesthetic reasons, I don't want to cut any access openings into the paneling above the headboard. If the insulation is styrofoam, I wonder how hard it would be to get a wire from the roof through the styrofoam and down to the pass through storage. Does anyone have any experience with a similar project?
Thanks for any tips and suggestions!
