bbaker2001ExplorerApr 10, 2017rpm when towingWhen towing with my ram diesel how do I tell when I should downshift. it seems to tow so easy, but slows when going uphill at 60 what should my rpm show.
RCMAN46ExplorerApr 12, 2017OK I will take a Cummins that is geared so that I am at 2800 rpm full throttle going up a 12 percent grade with 20,000 in tow.You take the same exact Cummins that is geared to run at 1700 rpm full throttle up the same grade and same load.I will be at the top having lunch waiting for you.In case you are not aware I will be putting about 100 more horsepower to the ground than you.
Related Contenttowing rpmRPM's when towing uphill?Towing lights issueRPM while towingTowing Speed / RPM dilemma
