bbaker2001
Apr 10, 2017Explorer
rpm when towing
When towing with my ram diesel how do I tell when I should downshift. it seems to tow so easy, but slows when going uphill at 60 what should my rpm show.
4x4ord wrote:
Here is some facts for you:
Gasoline has more energy per pound than does diesel.
Diesel engines need more air to burn their fuel than do gasoline engines. So when comparing a gasoline engine to a diesel of the same displacement the gasoline engine will make more torque and because it can be designed to rev much higher it will make much more Hp than the diesel.
The designer of the diesel engine (Rudolph Diesel) predicted that due to the slow burning of the fuel, the diesel engine would never be able to maintain operating speeds above 700 rpm. High pressure fuel injection has changed this.
Unlike gasoline engines, Diesel engines have been well suited for turbocharging for decades. The high torque of the diesel stems from turbo charging.
The reletvely recent development in direct injection gasoline engines is allowing gasoline engines to be effectively turbocharged. For instance the Honda 1.5 liter turbocharged gasoline engines make 108 lbft of torque per liter from 1700 rpm all the way to 5500 rpm. The HO Cummins makes 134 lbft of torque per liter at 1700 rpm but by 2800 rpm it is down to the same 108 lbft that the Honda makes. Peak HP of the Honda is 116 HP per liter. The HO Cummins is capable of only 54 HP per liter.
Although Diesel fuel has less energy than gasoline per pound it has more energy per gallon than does gasoline. This and the high compression ratio of the diesel engine contribute to its better fuel economy.
A high HP gasoline engine will beat a lower horsepower diesel up the hill everytime if the gasoline engine has the necessary gears to keep it in its peak hp rpm range.
