Bedlam wrote:
JumboJet wrote:
I went with DualLiner. DualLiner
You get more than just a rubber mat.
I have had Rhino liner in 3 of my trucks, but like the DualLiner much better. The DualLiner setup eliminates damage to the inner fenders, etc.
Do you get abrasion against the bed with the side walls? When I had a drop in liner the bed stayed perfect for 16 years, but I had to pull the liner every other year and touch up paint to prevent rust.
The trick to a poly bedliner is to use a liner liner. It is just a sheet of 1/8 polyethylene foam under the liner, anywhere it might touch painted metal. After 10 years with no attention at all, the paint will look like new. Without it, anywhere the bedliner touches the paint will be abraded away by dust and grit.
