biggjb's avatar
biggjb
Rubber roof confusion
I am in the middle of repairs on my TC and have removed a portion of the rubber roof due to holes and damage. I also repaired the roof and replaced the OSB with plywood. I am replacing only this portion of the rubber roof and am going to buy enough rubber roof to cover it. my confusion is when I go to various websites they state either EPDM or TPO material. Are they both the same with the same physical properties? Also, if they are different I am not sure which one would be better for the TC roof. Camping World sells rubber roof cleaner and repair kits. Can these products be used on both the EPDM and TPO material? Thanks in advance as I am coming close to finishing my TC.
  • AnEv942 wrote:
    biggjb, The existing roof on your 1999 Fleetwood Elkhorn is EPDM, if that was the question. Which for partial replacement I'd stay with same material.
    Though only because any other material, caulk etc, would need to be compatible with both if different used.
    All the EPDM Ive seen or used is black beyond the white top layer.
    Thanks AnEv942. This was part of my concern. I have removed about 8 feet of the front in my repairs and it was very time consuming and difficult to remove the old membrane. A procedure I do not want to do again for the remainder of the camper. My intent, correctly or not, is to replace the membrane I removed and place a strip of EPDM tape over the joint. I was also going to treat the old roof to protect it. I am hoping to get another 5 years out of the camper.
  • I don't think you will like that decision in another year, I would just pull it all up and put down new on the whole roof, even if you are looking at having it 5 years it will help with resale as well.
