jaycocreek
Nov 01, 2014Explorer II
It's a bad idea to put antifreeze in your fresh water tank..Yuck..Disconnect the line from the water pump that runs to your water tank and add a short hose that will reach to the bottom of a gallon of RV antifreeze and pump it through.
Even better is to just blow your lines out as recommended by many RV dealers.That's the way I do it and have never had a problem living in sub zero territory.Then add antifreeze to the traps/toilet etc and your all set.I always leave my faucets open,not closed while winterized.
Good luck...
Good luck...
