atreis
Nov 02, 2014Explorer
TNGW1500SE wrote:
If you don't put rv antifreeze in the fresh water tank, how do you winterize the fresh water pump?
The winterization kit goes in front of the pump, so the antifreeze gets sucked through the pump too.
After finishing, I let the pump push the antifreeze out of the low point drains also so that dewinterizing in the spring is pretty fast. There's not much of anything left in the system.
