mutt48's avatar
mutt48
run fan on 20 amp?
When parked at home I only have a 20 amp service to plug in TT. (2013 Keystone Bullett Premier). I know I can plug a small fan (home type) into the 110 in the TT, but can I use the TT fan (only fan, not AC), or does it take a 30 amp service to run unit?
  • I can run my AC at home in my 20 amp outlet. Just make sure if running the fridge or water heater that they are on propane. I've run the TV and DVD player with the AC driveway camping with the kids. Anything more than that will trip the breaker on the outlet.
  • Fan alone draws very little power, and actually you MIGHT be able to run the full 13,500 AC on 20 amp, but that could be pushing it.
    A typical 13,500 AC will run fine on 20amp, but not knowing what you are using for an adapter/dogbone or extension cords, it could be VERY unsafe if there's any components that are not rated for 20amp service. If all your hookups are safe, then you would need to ensure NOTHING but the AC was running in the camper (shut all other breakers off), anything beyond the AC unit could easily push you over 20amp.
  • RoyB's avatar
    RoyB
    Explorer III
    I run everything in my 30AMP trailer when plugged into 15/20AMP Receptacle at home. No problems at all. The only thing I have to watch out for is not have two high wattage things on at the same time otherwise it will trip my house breaker...
    My extension cord connected to the house is 10 gauge HD (10-3) Contractor type cords. I also use the RV30A-15A LONG DOGBONE type adapter (WALMART)... I have used a 12-gauge setup a few time but would not recommend anything smaller than 12-guage extension cord. Also do not use any of those small round RV30A-15A adapters. They will get hot on you eventually and burn up your shore power 30A Plug...
    I have two trailers connected to different 15A/20A circuit breaker zones at the house and is on 24/7 when my trailers are parked at home.
    Been doing this for years... I feel the connections whenever I am near them and they always stay cool to touch.
    We stay in our trailers off and on alot when parked at home. A great get-away/// Always doing mods to my OFF-RoAD Trailer when at home so having it hooked up aids me big time there.
    Roy Ken
