Bedlam
Jan 06, 2016Moderator
jeffreyduncan wrote:
Also, do you think that 245/70/19.5 will fit without rubbing? I'd like to stick with the 245 because of the H load rating. Using the 225 G rated I only gain 840 pounds vs the 1,980 in the 245. Not that I will be close to that, but I'd be close to the 840 - enough that if I am spending that kind of cash I'd want to go with the extra load.
You can run drive or steer on the front or rear. Open shoulder tread will make more noise up front than a closed shoulder design.
245/70R19.5 easily fit Ford and Dodge/Ram. GM trucks will require some front liner trimming or increasing the tension the on the front torsion bars to clear the fronts.
