the ammonia-water solution is mixed with a rust inhibitor made up of sodium chromate, it is an important part of the fluid for protecting the cooling unit, which is made of thin internally bare steel tubing… the fridge fluid utilizes a gravity system, that needs a precise amount of heat, good air circulation for exhausting heat, and above all it needs to be level for proper gravity flow and operation…
There is only one level everything else is not… that’s just a simple fact…
each degree OUT OF LEVEL causes a small reduction in performance and raises the temp of the ammonia solution due to inefficient circulation from the unleveled condition… if the temps are allowed to rise to much in this condition the sodium chromate begins to break down and separate from the fluid, and will eventually begin to crystalize and clump… left unchecked could be the death of the fridge…
all out of level damage caused is permanent and cumulative….
What is a problem and the most important maintenance item for a absorption fridge is being leveled during stationary operation… even small discrepancies in level can dramatically raise the fluid temps many degrees… all of which will shorten the life of the fridge and raise the risk of complete failure and the fire risk…
There is only one level everything else is not… you will get a lot of argument about this but its true…
The three things are needed for good operation of the fridge…
Level Level Level
Air circulation and ventilation
And a precise heat source…
"Amish cooling unit is the answer to your problems."
Just a thought about Amish cooling units… the Amish have vast experience with absorption fridges, but they have very little experience with mobile absorption fridges…
I think they have made some changes, and made them a little more efficient which is great. But doubt they have much in the way of testing facilities at their disposal…
I, IMHO do NOT believe that a Amish cooling unit is the answer to all your/our problems, or are the holy grail in refrigeration… and while the seem to do well in the hearsay dept., the difference is there are just not enough in use to say one way or the other…
But they too have had problems with catching fire, and with so few in use hearing about one doesn’t bode well for them… and I have heard about 2 or 3 of them so far…
Here is a picture of a burned out Amish cooling unit… I have more I’ll post if I can find them…
